Hi,
Part of my 1996 LC's brake lines was leaking owing to some tiny rust holes (I guess I had moisture in the fluid). I replaced with a piece of flared tube. But the tube that I used is slightly longer than the original that I cut off. It's hard to have exactly the same length of it. Not sure if it has something to do with the spongy brakes.
I bled the brakes after doing "bench bleeding", which was not the real bench bleeding: I left the MC on the car but unscrewed the connector on top of MC, blocked with a stud; replacing the one on the side with a bleeding connector and a plastic tube. It had tiny air bubbles at first but after quite a few pumps of the brake pedal, no more air bubbles.
I asked my wife to press the pedal. I bled 3 to 4 times for each brake, starting from the rear one on passenger side.
I saw some air coming out of bleeding valves but not much. It feels a little bit better than before the bleeding but still it goes all the way to the floor.
Not sure if it's true or not. I had a 92 LC before. It had never had these problems: the exhaust system last life time; no brake line problems (even I saw some obvious cracks on the rubber brake hose but still held). But on the 96 LC, about 80% of exhaust has been replaced; so are the Oxygen sensors and more. I got an impression that the steel parts of the car have a stronger tendency of rusting than the old model.
Thanks in advance.
z_johnq
Thanks in advance.
z_johnq
