Steering column query - should that be there
nick_the_fish
great_britain
After doing some work in the engine bay I had a quick look around to check if anything was in the wrong place as I always do, and noticed this
It's the steering column. Question is: Should that bell shaped bracket be fixed into the hole? It certainly looks like it should be. I haven't noticed it before, but then I haven't specifically looked at it.
Any thoughts? Currently in Guatemala, with about 5000km to do until we ship home, so hoping its all as it should be!
Thanks in advance
N
I don't think it should be.....try turning the steering wheel and I think you will find the bell shaped bit revolves.... if so then it can't be fixed to the firewall .
I think it's more of a protector for the grommet behind
@Grimbo you're right - it doesn't move relative to the bar, so can't sit in the hole.
@GeekOKent - if you could it would def help to settle my mind
@Shayne - yes - very good thought.
Once again the collective knowledge of the forum has helped to settle my mind, which has a tendency to worry while travelling (we're currently in the highlands of Guatemala)....
Thanks all - Very much appreciated.
N
It got really dark by the time I got away from work. Will do this first thing in the morning
