- Mar 1, 2010
REALLY annoying. It won't start or starts then splutters out. Nearly always the choke has to be over used witnessing fuel starvation. The electrics are super reliable but it might be worth checking the plug. Also witnessed by the plastic primer bubble not returning because it cannot draw petrol through the filter/s.
This applies to those types of carburettor that you can wave about or run upside down. They depend on VERY fine filters. There is one in the petrol tank and one in the carb. Probably best to clean the carb filter first. This is much finer than the one in the tank and easier to get at.
The one in the carb is accessible by removing the plate with one screw on. Beneath this there is a fine gauze pressed into the body of the carb. This is removed by sliding a strong needle down it's side and prizing it out. I examined mine with a microscope and saw corrosion or some other type of white powder so decided to wash it in battery acid an prod it with a very fine paint brush. It was defo blocked. Washed it in acetone and blew off with air line. It is possible to flatten the filter very slightly before pressing it back in.
Depending on the design the one in the petrol tank is easy or difficult to remove. If there is a large grommet it's easy to remove. If there is just a polythene pipe coming out of the tank then it's more of a job. There are 2 types of filter, either a blob of a fibrous material or a fine plastic gauze. The blob is difficult to clean. I shaved the outside layer off with a new Stanley blade and reversed flushed it with petrol in a syringe. I have not had a blocked gauze one yet but this could be cleaned by reverse flushing and prodding with a fine brush at the same time.
Anyway I've had 2 strimmers and 2 hedge cutters saved from the skip just by cleaning the filter/s.
I know it's a bit of a job but it is fixable and if it won't start it's a new one which will probably block up in 2 years anyway.
