Test 3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Sorry, but all coming through as a MIME encoded block of text.
I suspect that it may well be something to do with the mail gateway as
opposed to the your mail package (Outlook Express).
Here's something to try..
Go to Tools | Options and then select the Send tab.
Click the button for 'Plain Text Settings'
Under there, make sure the setting 'Encode Text using:' is set to none
and then give it a try.
Also do the same under the HTML settings button and try that as well.
Hopefully one or the other should resolve the problem.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
And exit out of the program and then go back in after 10 seconds.
