Pumpy
- Aug 6, 2015
My mate called it the Ark Royal for it's fabulous turning circle, the name has stuck
Modifications
Center differential lock has been modified to be selectable from dash rather than come on automatically with low range gear selection.
Raised Suspension 115mm:
EFS suspension kit, +115mm springs, EFS Gas shock Absorbers,
Front and rear anti-roll bar extensions,
Front and rear Bump stop extensions.
BOSS (FNB) radius arm drop boxes for castor correction.
Front and rear Adjustable Panhard rods.
New EFS Steering Damper.
Some Bushes Replaced with Polybush upgrades, anymore that need replacing will get Polybush upgrades.
Chassis & Body cavity treatment by Rustbusters.
ARB Heavy Duty front Winch bumper.
ARB Heavy duty Rear Bumper step with detachable towbar.
Intercooler
Safari Snorkel with snazzy BOSS stainless bullhorn cover
Autohome Columbus Variant series Rooftop Tent.
Patriot Alluminium Roof Rack
Oztent Foxwing Awning with 2xTapered side Sheets.
Toyota Winch with 50M Synthetic rope & HD recovery hook
Winch-it synthetic rope fairlead
Engel Fridge/Freezer
Gullwing doors (replace rear side windows)
Parrot Bluetooth Hands free telephone kit
Side & rear windows tinted
External Windscreen Sun Visor with 4x LED roof light spots
LED winch light
2x HID spot lights
Kenwood KDC-DAB4551U CD player/Radio/MP3
Wouxun KG-uv950P Tranceiver
1xCB aerial, 1xVHF aerial, 1x aerial splitter
Cabin lights upgraded to LED x2 with LED light strip worklight inside tail lift
110ah Leisure battery installation for fridge with 5x12v sockets for additional outputs
Bespoke LCD battery monitoring system in cabin
Blunt Force Cargo Netting above loadspace
Blunt Force Spare Wheel Bag for Firepit/BBQ
Bespoke overland storage system/draws/cupboards in loadspace/rear seating space
Hayes Security digital vehicle safe
Bespoke front seat covers from Escape Gear S.A.
Bespoke side steps/Heavy duty tree/rock gaurds
HD Aluminium Steering Guard/bash plate
HD Aluminium Under body Transmission Guard
Side window Smoked glass wind deflectors x 4
Cooper Discoverer STT 315/75 R16 tyres
Restoration Repairs & Work Carried out Since Purchase:
Air conditioning system service & regas 22/8/15
Front Axle rebuild LHS 1/12/15
Handbrake rebuild 1/12/15
Injectors refurbished, fuel pump reset & sundries
LSPV replaced and load-tested/bias set 12/12/15
Brake Master Cylinder replaced & sundries 21/3/16
Oil & Filter change 21/3/16
Engine rebuild, new pistons, bearings, conrods, big ends 11/5/16
Cylinder head rebuild, pressure tested 11/5/16
New waterpump 11/5/16
oil & filters 11/5/16
timing belt & bearings, and sundries 11/5/16
Post engine rebuild oil & filter 26/5/16
New Wheel bearings 16/6/16
Post engine rebuild oil/filter change 16/6/16
New Rear Brake Calipers, ARB drop links, bump stops 23/6/16
Retorque Wheel bearings 23/6/16
Drop boxes fitted 23/6/16
New handbrake shoes 23/6/16
Oil & filter 26/9/16
New fan belts & Air con belt 26/9/16
Modifications
Intercooler
LED winch light
2x HID spot lights
