This Forum. Paragraph no good.
frank rabbets
Guru
When I type a reply and want to start a new paragraph my cursor will not drop down. So I have to type one long string. My email typing is OK. Any ideas. Frank. See what I mean?
think you have to run the site in compatability mode ..... little box thing like torn paper up in the top right corner on your browser ....
Can you tell me what version of browser you're using?
So, when typing you press enter and nothing happens?
While the fix mentioned should work I'll see if there is a proper fix. I'm using the most up to date version of all browsers and have never seen a problem. Very odd
Sent from my GT-I9300 using Tapatalk 2
Had the same, but works now.
See :)
Thanks for the replies. Crispin when I press the button with the horizontal arrow pointing to the left having a small vertical tail on its' right nothing happens. Before when I pressed it the cursor would drop down to the extreme left hand margin on the line below. I think I have internet explorer version 10 as a pane opened up the other day saying "welcome to your new browser" and I think it said the above but I did not read it as I did not realise I had a new browser. Frank. See it still does not work. I'll try the compatibility thing if you cannot sort me. How can I find which browser I'm using?
Dang - It does not work on my machine now :) See... No enter. Ok, will look into a fix for it...
cvvbdxfb
all fixed!
Let me know if it works please. You should not have the previously mentioned "torn paper" thing at the top of your browser.
