Turbo Lagg
Also cut out the main exhaust box replacing it with a straight through pipe - this drastically reduces the back pressure and then when you increase the fuelling via the boost compensator it picks up well from low down - with a bit of tweaking I have very little turbo lag :)
After I did some investigation, I saw my exhaust manifold is cracked. Will this cause turbo lagg?
Can u be more specific.
When are you hearing turbo spool up?
You will always have some lag.
Can't say as I notice any lag in mine, just starts pulling and builds. The A8, now that had lag, but it was worth the wait :p
Boost at lower rpm's is dictated by the amount of fuel put in initially, quite simply more smoke low down = lowering the boost threshold (or what is often wrongly referred to as lag) Adjusting the fuel pump will have the most effect, its that or resize the turbo.
