- Mar 1, 2010
Is there valve overlap on the 12 or 24valve engines? There does not seem to be much room with the piston on TDC on the exhaust/induction part of the cycle for the valves to be open much. Just thinking of the tapping noise in the other post. Presumably if there is overlap and the bebs start to let the piston go further and further up the valves on overlap would be the first to be hit. If that were the case the valves would be against the cams, not so on the compression/ignition part of the cycle, and this would cause damage to the valve gear as well as the other parts of the engine.
Anyone know if damaged valve gear is associated with beb failure?
Just find it all very interesting.
