Re: What is it that limits how much the front of an 80 can f
Ryan Thomson said:
So would you say design wise it's binding of the radius arms in the set up that limits the flex?
Yes, once you've established that your shocks/ARB/brake lines(!) aren't limiting travel.
I'd imagine that drilling the bushes would make them more flexible, and allow more rotation of the arm around the axle, though by the time you've drilled enough to make a worthwhile difference you *might* find a negative impact on on-road handling, with the axle being less firmly located, especially under heavy braking or elk test conditions. Presumably the bushes wouldn't last that long either. Slee's products are usually well-resolved so could be a better option.
I don't think a rose joint at the chassis end would make much difference as a first step - though it might help once the limits of the arms rotating around the axle have been improved.
There are two 'directions' in which the front arms can bind - the first being the relative rotation of the arms to the axle casing when one side is on full droop and the other on full compression. The second is the twist of the axle relative to the chassis, though I think this usually only presents real problems with caster correction bushes which necessarily have less travel in this respect.
I'd forgotten about the X-link - certainly gives impressive flex, though doubtless at a price.
TBH unless your wanting to win twist-off competitions I don't think it'd be worth going beyond what the stock bushings will allow - lifting a wheel here and there isn't that much of problem and you can almost always get through anyway with a little momentum or use of axle lockers.
Flex tends to be a big subject in the Landrover world as they don't come with lockers and tend to break stuff if they use too much momentum (allegedly
The Superior Engineering kit looks like it would improve flex - ISTR they were working on an 80 kit, though again it might give interesting handling under heavy braking on the road.
As Jon suggests, find out what is actually limiting your travel and tackle that first; judging by the photos I'm not sure you're at the limit of the bushes yet. I'd also concur with spacing the ARBs - whether they're limiting travel or not they will work better in the correct position relative to the axles.
Let us know how you get on,
Toby
1990 HDJ80
1994 HDJ80
