Wheel spacing
Hello guys,
On my recently acquired KZJ71 I have swapped the 31 x 10.5 AT's for a set of
32 x 11.5 BFG MT's on the same alloys, which are 15 x 7's. Initially I
thought the tyres will be too wide for the 7JJ alloys, but they fit OK. I've
also installed an OME lift kit.
I'd like to get the wheels to stand a little further out without causing any
rubbing off road, somewhere in the region of 25mm. Ideas that springs to
mind is wheel spacers or perhaps swapping the alloys for wheels with the
correct back space. Any suggestions (without breaking the bank)?
Cheers,
Dirk
'93 KZJ71 OME Lift Kit
The content of this e-mail and any attachment is private and may be legally
privileged. If you are not
the intended recipient, any use, disclosure, copying or forwarding of this
e-mail and/or its
attachments is unauthorised. If you have received this e-mail in error
please notify the sender by e-
mail and delete this message and any attachments immediately from this
system.
Kingston Communications (HULL) PLC is a public limited company incorporated
in England and Wales
with registration number 02150618 and whose registered office is at 37 Carr
Lane, Hull HU1 3RE
Hi Dirk,
If you go the spacer route, don't pick up the cheap ones on ebay - the ones
I have seen are really thin cast alloy that look as though they would crack
at the slightest hard knock.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
