Do any of you know if Numax Deep Cycle batteries are any good, (I've found some that are half the price of Optima's) how do they compare with the Optima's? one of my Optima's is kaput, would it be wise to replace both?
Why is that Crispin, these batteries sayCrispin said:I did not think a cyclic, or deep cycle, battery is a good idea for cranking batteries?
sae70 said:I have to say I'd go with the Numax (gel filled glass mat tech) I had one on my Vit & was very pleased with it
Here's a link to my original thread on the subject on SS http://www.shropshire-suzuki.co.uk/foru ... f=6&t=6025
And some text from the thread
The battery on Snowy has finally given up the ghost with all of the cold weather and lack of use It's on charge now for the third time in as many weeks, but to be honest I've seen more life on a Butchers pencil
So 'Time for a dual purpose yellow top Optima me thinks' and set about searching the net for the best price and the correct fitment, but here starts my bemusement as the Optima that seems to be the most widely available and most commonly used by the off-road fraternity is the YT U 4.2 55Ah 750 CCA battery
Photo:
with additional terminals for the easy attachment of boys toys a close match in size to for the current factory fitment of an 70Ah 400 CCA battery But imagine my dismay to find more negative reports about Optima batteries than positive and a price tag of £165 plus postage
So after further investigation I have found two other batteries that seem to be getting good reports from the leisure/off-road community as a dual starting/deep cycle battery
The first being the DEKA Intimidator 9A78DT
Photo:
again a 55Ah 740 CCA battery with additional terminals, but I can't realy find anyone activly selling these on-line and the prices I do find are around the £120 mark plus postage
So after much reading and searching I find another new battery to the market place that many peeps are ranting about made by NUMAX called the CXV-X
Photo:
this is 86Ah with 1000 MCA (Marine Cold Cranking current is measured at 0 degrees C whereas the more commonly quoted Cold Cranking Amps (CCA) is measured at -17.7 degrees). So again a very simular batery to the others if not just a little bit more gutsy also with the additional terminals for those boys toys Delivered to your front door for only £100 from X-Eng
I'm prety certain my mind is made up But wondered if any of you lot had anything to add to my findings before I pull out me plastic and blow the kids school uniform money =))
Hope that this helps you
I've just rung Toyo and two batteries would cost £122 as against £172 for the Numax pair. The Toyo one only has a capacity of 65a, and they don't know what the CCA is. Whereas the Numax battery has a capacity of 86Ah and a CCA of 1000a. No contest I thinksae70 said:I also forgot to say that most people on here seem to advise just going to Toyota & getting a new OME one from them as they are a very good battery @ a very good price & I'm sure that that's what I'll be doing when the time comes
