MisterCruiser
- May 28, 2014
So on my 120 manual gear box 5 speed cruiser, there is a whirring noise, hard to describe but I've had a friend listen with me and it's a typical diff noise.
It's very annoying, drowns out the radio a bit. I had wheel bearing noise too but replaced that and now left with this other noise.
There's nearly 300k miles on my cruiser I should probably mention.
When I'm on the throttle driving normally it's not there, as soon as I come off the throttle the noise appears and goes away again when back on the throttle. I renewed all the fluids about a year ago, have only done 1000 miles or so since, was a project and I don't use it much. All the old oils seemed ok, definitely weren't the original oils so had been changed before.
I also have a small issue with selecting reverse gear only. Sometimes it will grind when selecting, but I overcome this by selecting 1st gear first and then slide into reverse, this works fine all the time and I do it out of habit now so isn't an inconvenience. I only mention this so it can be ruled in or out as the noise source. Could there be a bad bearing in the gear box which could be the source of the on/off power noise?
Or is the on/off power noise more inclined to be the diff? It sounds like it's coming from the rear to me and my mate.
Also, my cruiser can pull harshly to the left under braking sometimes, I read when searching that a worn diff can cause such pulling amongst other symptoms. I'm happy that all my calipers / pistons are free and not seized.
Is there a way I can diagnose the noise to be the rear diff? If i remove the rear propshaft? When undersealing last year, I had both prop shafts removed for access and had them checked by a mate who repairs them and they were both ok. However, I think we did see a bit of play at the rear diff, I can't remember but my mate loosened the large nut on the rear diff for some reason where the prop shaft connects. He tightened it up again but does that nut alter the crown / pinion thing and shouldn't have been undone or does undoing that nut matter much? I'm just struggling to picture it here.
Some tip for diagnosing would be appreciated.
