- Feb 24, 2010
Today I clicked over 90k and the T-belt light came on.
Mr-T said it is an hours work so not a killer (how numb have I become...) but if I can save £100 then...
Going to have a stab at changing it myself. Anything special I might need?
On the 120 access is pretty good, might have to remove one rad pipe to make things easy but about 6 bolts, plastic cover off. Mr-T said there are no idlers to change unless they need it but not part of a service item.
From all the youtube vids I've watched (both of them ) it seems pretty straight forward.
The one was simply marking the pullies and marking sure the marks are still in place when done. Did not bother with the casting marks. An ok practice or should I line it up with the Mr-T ones?
