More information would probably help ... as in as much information you can possibly tell us about the sound and what is happening when it occurs
Are you sure it isn't the power steering making the noise? Might need bleeding.
I had a similar problem until i changed the front anti roll bar bushes , heres a pic stolen from a thread by Fridayman , see it all here http://www.landcruiserclub.net/forums/showthread.php/41756-Front-Anti-Roll-Bars
I can't imagine what bar you jacked the truck up on but it seems very likely to me you have bent it so everything connected to that bar is now under undue stress .
Just to clarify, the bar I am referring is the front wheel axle (underneath the oil pan/cover). I removed the oil pan/cover before I jacked it up.
Well you never bent that !
Can't you get under the truck a let someone else turn the steering so you can work out exactly where the noise is coming from .
