Lorin
- Mar 28, 2010
I decided it's time to have a clear out of 80 parts. I am aware that some of it has little/no value and I am happy to give it away (or throw it away if no use to anyone) whereas other stuff is worth a bit. There's no prices as I simply haven't sorted any - if you're interested in anything just let me know and/or make an offer - I have photos of everything.
If it can be posted I'll post it. I can also bring bits to Lincomb.
The list:
2x brand new front Old Man Emu shocks N73 50mm lift - SOLD
Selection of 80 wheel centre caps - SOME LEFT
ABS pump and harnesses - working when removed though possible fault in a harness
New unfitted Safari snorkel - SOLD
2x new Milner stub axles
2x new OEM rear ARB links and bushes rod style. Part no 48802-60030 - SOLD
Set of second hand injectors - SOLD
New water pump non-OEM
1HD-T injection pump that I believe is either new or rebuilt - has a damaged plug - SOLD
Second hand 1HD-T injection pump with ACSD - SOLD
Second hand 1HD-T turbo and manifold - SOLD
Second hand front diff - SOLD
Rear bumper and side steps in good condition
Old LSPV with mounting bracket and rod
New OEM LSPV - SOLD
New OEM LSPV mounting bracket - SOLD
2x new Interparts CVs with ABS rings
Airbox lid
Second hand fan hub
Rear heater assembly
Full set of front seat mounting brackets/rails - SOLD
Power steering gear assembly
Set of front radius arms
24 volt starter assembly
3x used CVs with short shafts
3x used CVs with long shafts
1x used rear prop shaft
1x RH/drivers side OEM mirror glass
2x new OEM driver/passenger grab handles
New OEM interior lamp
Used 3 gauge pod that fits in gap between transmission tunnel and dash - SOLD
2x new OEM rear sliding window rubbers - SOLD
Used front diff lock actuator for spares or repair
Used centre diff lock actuator for spares or repair
DS sliding rear window
The list:
New OEM LSPV - SOLD
Airbox lid
Second hand fan hub
