- Mar 1, 2010
My 80 now drives on rails as I've adjusted the steering box The fwm isn't any good so here's how to do it.
1. Best after front axle rebuild but the below applies if you just want to adjust.
2. Slacken adjusting nut.
3. Hold adjuster screw with screwdriver and remove the nut.
4. Put car on front axle stands so both wheels off the ground.
5. Centre steering wheel.
6. Screw adjuster screw in hard and completely till it stops.
7. Turn same screw back so it just becomes loose the back carefully until you feel it tighten again. Usually 180 degrees.
8. Turn steering back and forth once to each full lock using road wheels, not steering wheel.
9. Check screw is still loose to turn clock wise and turn until resistance is just felt. Put nut on and tighten without moving the adjuster. If screw is tight clockwise go to 7 above and repeat.
The adjuster pushes the steering box spindle in and out of the box. There is 180 degrees play before it pushes or pulls the spindle. The spindle is a bit like a shuttle cock having tapered teeth on it. Screwing it into the box takes up any wear. Wear may be uneven so when you move the steering back and forth any high spots push the spindle back up into it's tightest practical position. That's why you have to loosen the screw otherwise the screw will not allow the spindle move back out.
Check by taking the car for a run and make sure the steering wheel returns properly when straightening up after a turn. If no return the adjuster has been overtightened and/or there is a high spot not adjusted for.
Frank
Frank
