- Mar 1, 2010
Worth stripping the pump and seeing the condition of the PTFE coating on the pistons. If it's not damaged by lack of oil the pump could be rebuilt. The other point is the condition of the shaft where the seal goes. If rust is there it might not be possible to polish it out on the lathe. However parts from other similar pumps are interchangeable subject to a quick side by side check.. I made a good pump from three scrap ones.These pumps are fool proof re leaks after reassembly especially if done by someone as careful as you Chris. I'd never done one before. I'd put 8 ounces of oil in even though some might be left in the system. I think a lot is lost in the form of lost mist when there's a leak leaving behind not much of a witness mark.
