Knucklehead
- May 28, 2013
Was wondering if anyone on the forum has had a similar problem with their rear suspension.
Quite a few years ago now I fitted the Pedders 2" heavy duty lift kit to the 80 and back then if I hit a big enough pothole there was an almighty metal contacting with metal bang.
As it happened rarely and not when off-roading I put up with it. Should have sorted it then but im a lazy git.
Now I'm finding with the roads being in such a crap state it is happening every time I hit any uneven surface like sunken manholes or even smallish holes to the point I'm trying to pick the smoothest part of the road while driving. Not fun.
Had a good look under the car around anything heavy that could be making contact but the waxoil coating is showing no parts contacting anywhere. The cruiser is still sitting well with no visible drop so suspect the springs are still good.
I then wondered if the shocks were stuffed and bottoming out with the weight of the 35" tyres as I never fitted extended bump stops though wouldn't have thought the axle should be anywhere near bump stops on the road. I tried fitting a near new spare set of Pedder shocks that made no difference. Same bang from the back axle.
It's odd as only happens on a sharp up/down movement of the rear axle like a pothole and only the rear, no issues with the front even though it has all the weight with engine, bar etc...
Ive tried jumping up and down on the back step and pushing side to side but again nothing but normal shock sounds doing their job. Only xtra weight currently in the back is the spare wheel.
I was thinking about swapping out to adjustable shocks but thought best to try and find what is causing this issue before wasting money on them.
Any thought would be much appreciated as my knowledge of shocks and springs and how they work is beyond my head.
Cheers, Dave,
Cheers, Dave,
