knicko
- Dec 23, 2012
Got the MOT coming up in a couple of weeks and while I'm fairly happy (touch wood), as it was a dry day I thought I would attack a few jobs in anticipation of the test.
1. Strip the rear disks, fit the extended dog bones and generally lube the handbrake parts etc
2. Fit new rear ARB bushes that I've had on the bench for a few weeks (rear drop links already done as they were totally shot)
3. Fit new front ARB bushes and drop links, which I bought at the same time as the rears
Job 1 - all completed easily and handbrake nice and efficient (thanks for the modded dog bones Chris). Only thing I've noticed on these is the handbrake pulls up tight on about the first click while you have your foot on brake pedal. Then as you release the pedal, the handbrake goes slack and needs pulling up a few more clicks before it holds firm. Not sure why this should be as the footbrake disc pads and handbrake drum shoes are independent of each other?
Job 2 - went to release one of the two 12mm bracket bolts on the offside rear ARB and sheared off the bolt... of course!! Why oh why do these Japanese 4X4s make their bolts out of cheese? More luck than planning, but at least the bolt I sheared was one of the easier ones to access the captive nut on the inside of the box section. I was able to drill through the whole lot and replace with a stainless nut & bolt. I've left the rest of the bolts well alone and will hope the ARB bushes are good enough to pass the MOT as they are. Thank god I didn't attempt to remove the nearside ARB bracket first as on initial inspection, it looks like there is no easy access to the captive nut inside that box section and I'm quite sure I would have sheared the bolts.
Job 3 - not even attempted after the close shave with job 2. I will plan to do jobs 2 & 3 when the weather is better, there is longer daylight and I am prepared with the right tools to deal with those cheese bolts!! Never gets boring.
