Just watched the vid and luck gets my vote , its a good example of why i don't like trucks that are jacked up too high , in an ideal world width should be increased to correspond with height , a double decker bus can be tipped sideways more than 45 degrees but will fall back on its wheels because it was designed that way and so are most 4x4's but lift without increased width lowers that safety margin .
Notwithstanding the numbers of lean degrees Shayne, I certainly take your point.
When I modified my suspension, I was lucky to be able to discuss it with an "expert" from the UK who was an importer of OME and ARB products into Romania, he was first and foremost an entrepreneur "milking" a niche market here, but in order to succeed, he had done his homework in a practical sense and was also a keen overland and off-roader, and a huge admirer of Land Cruisers, having his own modified Amazon HDJ 80, which was a beauty.
Long story short, we drank a fair amount of beer over a period of six months or so, discussing the pros and cons of suspension lifts, body lifts and the various combinations of wheel offsets, spacers and the like.
Basically, I concluded that body lifts have the advantage of maintaining a lower centre of gravity, where the relatively heavy chassis, engine, gearbox and related stuff is kept as low as possible, whilst at the same time increasing the available space for bigger tyre diameters and the other advantages of lifting.
On the other hand, suspension lifts, or more accurately upgraded suspension to provide longer travel to prevent wheel lifting on severely undulating ground, is also desirable for obvious reasons.
I chose not to have a body lift, mainly because my usage was not thought to be extreme enough. The suspension lift was therefore chosen to be moderate, I've always thought it was 75mm, but when I've checked my records since, I realize it was 110mm!
Anyway, he a point of taking care that the lift wouldn't put me in danger of becoming "top-heavy" and with widening the track of the truck with our choice of wheels and tyres, I think we struck a good balance.
I can still do a body lift if I choose, but as a daily driver, I don't want to make the truck too impractical for daily use.
For me, the video shows the importance of control of the truck. I got the feeling that at that particular moment, he'd lost control, and the crowd thought so too! Nevertheless, by skill or luck, he held on to it, and continued to control it nicely to the top. So many of these vids show blood and thunder approaches to difficult terrain, and often end in disaster.
This one was a pleasant change for me.
