Iwan
- Mar 28, 2011
In the process of getting this project to move forward, the most missing bit of kit is a good compressor.
I had looked at new ones with the limited budget and at second hand ones.. which I think is a very dodgy way of going about it! Just imagine buying a shagged ex spray shop compressor!! Back at stage one so to say!
So I decided to rebuild this.. which I bought for £25 many if not about 12 years ago!
Bought it but never done anything with it. I did a bit of research on it and it turns out to be a very good quality 160 litre tank made by rednal pneumatics! The pump and motor were knackered! And remembered that the guy said that the on off switch unit was new before I bought it.
Apparently the metal thickness on this is twice as thick as the new ones that are made from chinesium!
A 3 horse power motor and after looking into it, it has a very good italian made pump.... a k18c made by chinook made in Italy! Twin cylinder 16cfm pump. Same pump as on the rolair twin cylinder compressor.
So after looking I managed to buy a new old stock pump thats a straight bolt in replacement, admittedly a bit
more expensive than the made in the prc but original to the tank. The capacitor start and run motor is pure chinesium!
The motor came setup for clock wise motion as above... for this pump it needs to turn counter clockwise. So to rectify this, you undo the connecting bars from horizontal and reconnect them vertically i.e. fit the bar to connect u2 to v1 and the same for the connectors on the left.
I bought a cheap clearance regulator, filter and tool lubricator. Then fittings and pipe etc.
Lookin good! Just waiting to receive a new 125mm pulley for the motor and jobs a good one! Really enjoyed this little project and am sure that I'll have more compressed air than what I need and a better bit of kit than a a new one with a thinner walled tank!
Happy days!
Happy days!
