Joe_W
- Jan 22, 2019
My trusty LC has recently developed a problem with the central locking. It is intermitent and occasionally goes back to normal but has more recently been consistent. I always use the key rather than the remote.
The symptoms are:
1. Doors unlock with key, when a door is opened all the doors then lock themselves. Once this happens the key will only unlock the door it is used in and not the central locking. This only happens when engine is not running.
2. Lock/Unlock button on drivers door consistently works.
3. When the interior light is switched this seems to operate the central locking?!
4. When locking the truck and central locking not working, the key still operates the immobiliser, turns off the interior lights and ignition barrel light.
5. The other day the speedo, odometer and rev counter stopped working. This then started working once one of the doors were opened and the doors locked as stated in point 1. The speedo etc also would cut in and out when I pressed the lock/unlock switch on drivers door. This has now gone back to normal and only lasted a few days.
6. Fuel gauge recently has been intermittent and shows empty with flashing fuel light. This then goes back to normal when restarting the truck.
Im sure its all related somehow but now need to get it sorted as its quickly becoming a PITA trying to get everyone in the truck when every time a door opens it then locks itself!
Soooo any wiring diagrams out there that someone could share? Also if anyone has experienced something similar or can share any suggestions on this it would be greatly appreciated!
Joe
The symptoms are:
Joe
