- Mar 1, 2010
I should just get a hone=glaze bust done if possible then you might be able to use the original pistons. Ask your engineers advice. A problem I used to get after a rebore was swarf in the oil ways which may be impossible to clean out without everything off the block. A glaze bust is less risky. Again ask his advice on whether he can blank off the oil ways and wash the block down after he has finished. When the bores are cut as in rebore it creates a lot of sand like swarf, or used to on the blocks years ago. He might also check to see if the block is warped or not.
A brave job being carried out.
