- May 13, 2019
Neither is the 5VZ, that engine has a motor based cable actuator for cruise control.
Is this 6 pin white connector installed by default in the prados 90 or should it come with the CC stalk? From reading posts I would assume it is installed by default - for horn wire.
Thank you for the insightWelcome, I'd guess you're trying to use the CC stalk from a petrol 90, it won't work, as won't one from an 80. I tried the swap from my V6 Collie ( Prado) onto my KDJ 95 and it didn't work.
You need the 2 wire stalk from a Yaris ,Avensis etc from the same era. Hope this helps.
Now I have to figure out how to mount it...
I cannot understand why it wasn't fitted as standard when it's all there bar the stalk.
Haha yes, I sure did, no CC unfortunately : (Can't help with voltage.. but I will ask the ridiculous obvious question.. I presume you went past 30mph or so when testing.. it doesn't work below about that.
Hi Laszlo, just wondering if there was some progress/an update on this topic. Also got a 1KZ-TE in a KZJ95 and would love a fix for installing CChello happy for your success...
sadly these all works fine with d4d but nothing i see here for 1kzte. SAAADLYY
if somone know how to do Cruise Control for 1kzte please post it. (diesel automatic)
Model: KD-KZJ95W-GKPST
Frame: KZJ95-0066290
THANKS!!!!!!
