- Feb 2, 2013
I obviously dont understand how this works .
To my thinking the normal factory set up sees gas build to a set pressure that spins the turbo , when that pressure is exceeded the wastegate opens releasing gas and causing the turbo to stop working . If an in-line boost controller was introduced it would allow more pressure to build (allowing the turbo to run longer) before releasing the higher pressure gas in exactly the way it would normally .
This is were my lack of lingo causes problems .
Is it the actuator that allows pressure to build ? if so the manual boost controller might be looked at as adding another actuator , one that will allow more pressure to build for the factory set up even comes into play and without leaking thus not allowing the wastegate to open slightly before it should . This turns the factory actuator into nothing more than a release valve because as soon as the after market booster opens so will the factory one as the pressure that hits it is likely far higher than its set to accept .
Am i way off the mark in my thinking ?
