BRE Fabrications LTD
Right,
So after having a set of custom valved 12" Fox 2.0 Remote reservior shocks sitting in my shed gathering dust for the best part of six months, I'm finally on a position to start getting these bad boys fitted along with the Slinky's I ordered from Overlandcruisers.
Now just to clear up a bit of background info, I decided to order the Slinky coils from Julian and then order the Fox shocks from Downsouth motorsports in the US. The primary reason for this was cost. I couldn't quite swallow the price of getting the Fox shocks as part of the slinky kit that is offered by ATS4x4 available through overland cruisers (Circa £2.5K).
For those that are interested costs came up as:
Slinky coils - £610
Fox Shocks Landed - £800
Total so far= £1410
There will be other costs which I'll document as I go along ie: extended brake lines, materials to fab up drop blocks for my bumpstops and swat bays etc...
So here are a few pics of the install, I only have the rears on at the moment. I still need to drop my bumpstops and extend my swaybay mounts.
Slinkies Vs OME
Fox Vs OME
Fitted:
I few things I have noted so far:
Measurement from Wheel arch to Rim both DS and PS - 400mm.
DS up travel availabe - 100mm
PS up travel available - 90mm.
This is where I'm a little confused, I don't know where I'm loosing 10mm om the PS side
Also the travel available - 4 up and 8 down is not really where I want to be, I'm going to need to look at extending my shock mounts by and inch or two so I can be closer to a 40/60 or 50/50 setup (% compression/ % Droop). Not really what I wanted to be having to do... The idea was to have a bolt in setup. I did run the shocks compressed and extended lengths via JV @ overland cruiser before I bought them but I feel I don't have enough compression with the way it is currently.
Next weekends mission is to get the fronts on, after I service the Front axle.
Either way I'll be rolling on the fab works.
This is going to be a bit of a slow process so bear with me ya'll
Now a few questions for the gallery:
How much compression do you have available with an OME 2" lift setup fo you have?
What is the distance from rim to wheel arch with that setup? (I know I should have measured before I pulled it off... )
Slinky coils - £610
Total so far= £1410
Slinkies Vs OME
Fox Vs OME
Fitted:
