tony rodaway
- Aug 28, 2016
Hello guys.
I have recently replaced my n/s headlight plug because of corrosion.
The replacement part from ebay fitted the h4 plug perfectly.
After joining the new ebay part to my oem harness I had power.
Not giving it a second thought I assumed everything was OK.
Later on I went out in the dark and never noticed at first but my new harness
Fix has made my light loose power slightly.
I say this because my beam pattern on the road has changed and only have the drivers beam.
Pulling into my drive and facing the house the beam pattern looks no different and just as bright.
The following day I removed the headlight bulb thinking the metal bulb holder clip had come loose or moved.
The bulb was seated correctly and the clip was tight and I never removed the bulb on my plug change.
I installed a small light bar and it's connected to the same light loom but works perfect.
Since my plug change I have definitely noticed the difference in the light output.
I have h4 6500k led bulbs but we're also perfect before the plug change.
Just a thought but the new harness is about 7in long and just attached to my oem harness.
Can the wire length cause this difference in output.
It's nor a big issue just annoying because I know it was OK at first.
I will try get examples for you guys to show my annoying discovery.
