andrewlowe13 said:
I was wondering if someone could put me right on the different options / modes that the transfer box gives you please?
The Shogun is quite different (maybe partly at least because of the 2wd option), and there is no option to have low range without the diff being locked. This has a 'sequential' selector, and runs:
High / Diff unlocked
High / Diff locked
Low / Diff locked
Andy.
Andy,
Welcome to the site.
As you are doubtless aware, the UK '90-Series' Landcruisers have permanent four-wheel drive with separate gearboxes and transfer boxes, like the LR Defender, Discovery & Range Rovers.
They have a solid beam rear axle on control arms, panhard rod and coils. The fronts are independent with a double wishbone, knuckle swivel and coils (no Radius Arms and 'A-frames' with ball joints here
The Transfer box works as you have described for the Shogun . .
Transfer lever over to the left:
Back = 'H' - that is high ratio, centre diff unlocked.
Forward = 'HL' - that is high ratio, centre diff locked.
From the forward position the lever can be moved to the right:
Forward = 'N' - That is a neutral position (useful as a security measure
Forward again = 'LL' - That is Low Ratio with Centre Diff Locked.
It is not possible to have Low Ratio with the centre diff open as it is all mechanical and the selectors only work in this sequence. On the '80-Series' Amazons the Centre Difflock is electrically operated and it is possible to modify the wiring to fool the ECUs and run with the centre difflock open in Low Box
The Workshop Manual we all use is from "Max Ellery" - which is Australian. That shows a part-time four wheel drive variant, so the UK Colorados are not necessarily the same as the 'rest of world's' Prados. I'm afraid I'm not enough of a Toyota Geek to give you chapter and verse on all the variants out there
The UK 'Colorados' have an electrically-operated rear difflock (the electric actuator is prone to corrosion from road salt
) whereas the 'Prados' have a Limited-slip rear diff.
WHEN you come to buy one (
), check that it has all the functions you expect and ask here for advice as necessary as there can be 'mixes and matches' going on.
I produced an explanation of how the Transfer Box works here -
http://www.tlocuk.co.uk/forums/viewtopic.php?t=7927&highlight=transfer+box If you want to see all the gory detail
Bob.
