Iwan
- Mar 28, 2011
Yesterday took a slower hit on the project, I had a look at this. The fuel pin on the right is from the 24v engine and from experience.. well it's one of the poorest fuel pins that I have ever seen! Low travel and shallow angle! The one on the left is from a 2lt! Steeper and longer, admittedly after studying and measuring it many times yesterday, it's approximately .20/.25mm shallower. But it can be filed to the depth of the 24v one.
On the 24v (rhs) in this pic you can see the horizontal pin gouge. Very short travel and short boost in theory
This is the underside of the cap (smoke screw) and its set to determine where the pin gouge begins. With this my though and understanding is that to turn it to the shortest point which I've marked it out and moved. So that you can achieve the furthest travel of the pin. Have seen youtube videos that say to make this the minimum as at the lowest point it can make the turbo spool up quicker and also gain extra travel on the vertical pin, as apposed to setting higher and effectively chocking the engine with too much fuel to begin with.
The question is, am I correct with the way I am thinking about this??
I've marked all the original settings so easy to change the pin back and return back to factory restricted settings. I've turned this wheel 1 1/2 times at the moment and am going to adjust the main fuel screw not excessively.
I'd like to hear some peoples thoughts and experience on this.. if possible
Been struggling with the gear lever access on the auto, on the 60 and 70's they have a removable panel that you just swap! Not on the 80! The main problem is that it's really hard to determine where to cut the hole for the gear shifter, so have painstakingly removed the manual counterpart!
Have I ever said that I don't like automatic transmissions!
The motor is ready to go in, had to use the auto transfer wiring loom as the manual loom is too different even though it has the same connection plug. Have fitted a bundera reverse light switch to use as a 5th gear towing warning light and moved forward the reverse gear wiring over to by the starter motor, too hard to do when all fitted..
Keen to see this job done, not tired of it but not going to give up!
