It's been a while since Rex was treated with some goodies, so thought the next one should be a good one... After much deliberation I went for some +45mm Dobinsons springs with some shock spacers provided by Gav
First a reminder of how Rex looked with a saggy arse:
So, first step was to jack up that saggy arse and whip the rear wheels off to see what I'm dealing with:
The old springs come out with relative ease and on comparing them with the new ones they don't look that much different in size, however there are two more coils in the Dobinsons:
...so, utilising a set of these:
...they go straight in.
While the back was up I decided to adjust the load sensor - this needs doing to keep the brakes in check. You can see the adjuster above the diff on the left of this pic, I just screwed it all the way to the top and although there wasn't 45mm of adjustment available it seems ok (I'm sure the next MOT will pick up any probs):
Next, the shock extensions. Gav supplied four 45mm long hex nuts and the threaded bar needed to make the extensions. All that was left to do was screw the bar halfway into the nuts and cut them off to size. This is what each finished product looked like:
Unfortunately, when I pulled the bushes off the pins on the bottom of the shocks I found that said pins were only threaded less than halfway, which meant I had to find a M10x1.25 die nut to thread the rest of the pin so I could screw on the extensions
I cut down the pins and threaded the rest of the bar...:
...and screwed the extensions on:
All in place:
That's the back done
I ran out of time to do the front as finding that die nut took up the best part of they day
but managed to get to it a couple of days later... when I didn't have a camera with me
sorry! It was fairly straightforward anyway and I got the camera out last weekend when I tested the whole kit out in anger at Lincomb
Unexpectedly seems to flex a little better despite the limitations of the standard shocks... no complaints though! This is with the front anti-roll bar still in place:
and afterwards down on the Gower. Looks level with a half decent load which is what I was looking for, so very pleased with the end product
Up next, a full size spare and a start on replacing some half worn Coopers. Well, it's about time
Jim
