Does the reverse light switch work on the +ve or -ve? I'm on a rubbish computer so I can't open your wiring diagram at the moment!
with the exception of one of them that one side gave me 11.65 and the other side -0
Thanks for that - I would check for voltage at the reverse light switch next. That could give us a clue if the problem is from the battery to the reverse light switch, or from the reverse light switch to the light.It is manual
I really hope so. What I'm planning to do today it is to change all the fuses that give me cero reading in the on position to see if that change anything
Not sure what you mean by that. Does your multimeter beep on the continuity setting?I did that already and there was not current.
What I meant is that I didn’t get any readings with the multimeter. I will try using the continuity setting to see what I get.
Yes, it is indeed. I am annoying with myself that all this was self-inflicted though
