Adrian North
- Oct 11, 2011
Hi everyone,
I have a 1999 3.0TD Colorado which I bought a couple of months ago. Just before Christmas she overheated and sent a lot of water out of the overflow onto the inside of the bonnet. I took her into a garage and they found that the radiator was leaking badly. They have replaced the radiator but on a short trip after I got it back the overflow sent water out again even though she didn't overheat. I have read on here about this engines cylinder head issues so I feel that this is the cause.
However, this engine had a new cylinder head and gasket (both from Milners) last year (just out of warranty now but not when the problem occurred) and they are quite expensive so I was wondering, before I go the the expense of getting another head whether there was a definitive way of finding out if the hear/head gasket has gone without removing the head to see. The garage I used tried some or other dye test but that didn't show anything but they have said that the cooling system seems to be overpressuring slightly but I am too much of a mechanical numpty to understand what that means.
Thanks for any help or advice you can offer
Adrian
Adrian
