MisterCruiser
- May 28, 2014
Fellow cruisers, I'd really appreciate it if someone could just advise me on this.
I'm about to drop the gear box, everything is removed but I'm unsure about the gear lever, please see pic.
Can I leave the big gear stick in it's position and be possible to remove the gear box with it left attached? Or do I need to undo the 4 bolts and unbolt it from the top of the gear box? Or does it just pull out with force? I'd like to leave it attached if possible so as to disturb less stuff, but I need confirmation from some one first. I'm not sure if I'll have enough clearance to get the gear box off the engine if leaving the gear lever attached as it is in the pic?
Does the gear lever come apart more than in the pic, does the black handle piece unscrew from the metal lower part?
Will the black piece separate from the exposed metal piece at this point?
