Charlie
- Apr 9, 2010
Guys,
Just giving my truck a service after returning from Morocco last month, and found a leak from the transfer gearbox. Upon further investigation the oil leak is coming from level plug / cracked housing, is this housing easily changed in situ or will I be better off removing the transfer box assembly first before changing the cover?
I can only assume the last person to check the oil level over tightened the plug, causing the casing to crack…
