- Apr 10, 2016
It may be the power window relay in the drivers door rather than an ECU, at least it is on a 60.
Without it, the passenger and rear doors work fine by their own switches but the master switch panel wont do anything.
My relay is off a bj74 (24V) which fitted and worked perfectly. Mounting is low down in the bottom of the door so vulnerable if wading.
Anyway, could there be a break in a wire as it started playing up more and more - this can happen until the wire breaks completely.
Or as you said a dodgy or dirty connection.
