stumog
- Oct 3, 2012
Thought I'd post this as I couldn't find a definite answer to this while looking.
So I purchased a xforce from a long standing member here as they were not using it, still in the box.
Now x force will not say if they fit a 24v I can confirm they do. Now as mine isn't, as you say standard was a bit of a faf. I was missing 2 or 3 3 mounts and had a air tank installed where the center box is.
So first was get the old exhaust off no dramas. Bar working out how to get to the top inside dump pipe nut.
Next remove air tank. No this is where I should have faith that Chris did a proper job fitting it. So I remove the back seats and the carpet only to find that he had used rivnuts to mount. So I could have just undone the bolts holding it on. I have no idea why I didn't just try them first.
Next front pipe. Went on sooooo easy 4 nuts on the turbo ace. Then looked at what id done. Forgotten to run the rear of the pipe under the slider. Git.
Pipe back off the turbo, now doesn't fit under slider. OK take slider off. Easy. Well no. I actually managed to drop the slider from the full height onto my head. This was really painful and still can't touch my head 4 days later and have a small crater where I didn't before. So may head to the hospital tomorrow.
Made up 2 brackets and the exhust tucks up very nicely qt the back. If people are wanting to see will take photos but I read reports they sit low but you wouldn't be able to get a exhust any higher. The clearance on the body is good and routing was super easy. They seem very well made aswell
It sounds very nice can hear the waste gate and the turbo whine. The turbo spools up alot earlier bit and performance does seem to be to be improved.
Overall very please.
