100 series autobox prob
Hi everyone, i have a problem with a 100 series auto box. The car has
never missed a beat in 3 years of ownership. Runs faultlessly and
gets serviced regularily. Went away for a week and left the car in the
airport came back and started it, let it sit for a few minutes to warm
up then reversed out of the parking spot and went to drive away. The
car moved about 100 yards then stopped moving. Turned it off, started
it again and tried to move, same thing. Moved 100 yards and stopped.
Any ideas where to start? The fluid level is fine. Thanks. Brian.
Sent from my mobile device
Its a 2000my 4.2. Nope, no noises. Just no drive. Its like its got no
fluid but it does, its full. Thanks. Brian
Not sure about those 100 series, do you have a L/H lever, I guess so.
You aint got it in the middle of the two :)?
-----Original Message-----
Behalf Of brian creevey
Sent: 02 March 2010 16:28
To: [Email address removed]
Subject: Re: [ELCO] 100 series autobox prob
Brian,
Does it go if you continue to move very slowly?, try not to
exceed 5 mph and see if it stays powered, if so the 1st to 2nd shift
valve is stuck. Try to move with the second start button p
On 2 March 2010 16:27, brian creevey <[Email address removed]> wrote:
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
Sorry I did not see the previous post, didn't notice the vehicle actually
moves. If only it was that simple!
Behalf Of Martin Naylor
Sent: 02 March 2010 17:16
Subject: RE: [ELCO] 100 series autobox prob
Dave,
I have to ask, why the CDL?, I can't fathom that. Thanks.
Clive Marks
Hi,
What happened with this?
Clive Marks
hi everyone. apologies for not coming back sooner. i havent been able to get
online in days, thanks to THREE broadband being down and also dropping my
phone into 40 gallons of waste oil.its been a good week. i tried all the
suggestions and found if i kept it in D and held the revs at about 1800 it
would creep, albeit very slowly,but it did move. i started thinking all
sorts, "A" clutch dying, maybe the torque converter on its last legs. I
decided to investigate further and dropped the sump off the box. turns out
the filter was blocked solid, i guess after 150000 miles its to be expected.
a good clean and new oil and its like driving a new car, gear changes are
much sharper and happen quicker, it goes up through the gears so much
smoother. its never driven this good.
thanks for the input.
brian
On Sat, Mar 6, 2010 at 5:11 PM, Clive Marks <[Email address removed]> wrote:
> Hi,
> Regards,
> Clive Marks
