10mm Irwin rounded bolt removal socket
warrenpfo
Does anyone have one they could pop in the post for me to borrow and then return as i seem to have rounded one of the top 10mm bolts on the rear diff lock actuator assembly in the removal process and now I cant get it off.
If not does anyone know if they work as i guess for the sake of £20 i could go and get the set which the 10mm comes in as i am sure this will not be the last rounded bolt in my life.
I do not have a kit but they have been mentioned on here before. Generally seems to be a :thumbup: product.
Ian
The tension is located in the bolt head.
With a small dremel blade cut a cross into the bolt head and then fold it on itself.
You'll release the tension and be able to turn it out with a smaller socket.
