I was thinking of buying one of these, http://www.ebay.co.uk/itm/180747018492? ... 1423.l2649 , but the sensor is a probe type, not a clamp down one, I'm not sure how that can be attached that to the engine block, any ideas chaps
The sensor on that one should survive in an engine bay but the quoted temperature range is the same as the cheap one Chas posted ...ben said:it does look very similar to the more expensive one below.
http://www.ebay.co.uk/itm/110815948233? ... 1423.l2649
I'm watching that one too, they look identical apart from the sensors. I wasn't thinking of using it for control just as a more reliable means of monitoring.ben said:my mate ordered one of these a week or so ago. it should be here soon, so once ive had a look at it i will let you know if its any good. if it is, im going to get one.
What is the normal temp of the coolant Jon? I've just found another unit http://www.ebay.co.uk/itm/120858938113? ... 1423.l2649 which says "Temperature Controller SpecificationsJon Wildsmith said:What are you hoping to measure? How robust is that sensor / will it survive living in an engine bay instead of a fish tank and the temperature range doesn't look very useful - just about covers normal operating temperatures for coolant and sensors are least accurate at the extremes of their quoted range so it may not even be very accurate at those normal temps ...
