Dan_the_drifter
- Oct 4, 2018
Hi, bit of a long post, I apologise in advance
Amazon ownership has been going along lovely until the start of this week, went to start the truck up as normal to drive to work, felt a bit of a misfire when first started and thought it was nothing and at this point no smoke. Left my house and under light acceleration started to smoke a bit then cleared up and went away after about 20 seconds, shrugged it off and thought it must have been 'one of those things' and drove to work as normal. As the week has gone on it has started to smoke more heavily after each start especially from cold and the misfire under light throttle is quite bad to the point that I am driving it into work tomorrow and will then leave it there until it's fixed as not happy possibly causing any engine damage.
If you put your foot down it mostly clears other than some slight black diesel smoke expected when accelerating hard. For this reason I do not think it is a lack of fuel in terms of the supply to the pump as from my own experience it would be fine under idle/light throttle then starve under more load. Mine is the opposite of this.
Pulled the intake pipe to the turbo off and checked the turbo just to be sure even though I feel it's diesel not oil. No more play in the bearings then I would expect for a 220k mileage truck and no excessive oil loss on the dipstick so ticked that off the list. I have inspected the air filter, drained the fuel filter and all seem fine. I can visually see the swirl flaps moving when engine revved. The EGR has been blocked by a previous owner and the pipe to it capped off. Do not feel it is sludge build up in the intake etc as the fault has come on way too quickly in my opinion. Checked the MAF hot-wire and cleaned but again no difference.
I have fairly good history and it had been serviced well by the previous owner from what I can see so my gut feeling from being a mechanic is an injector or 2 sticking/injector nozzles blocked. I think it is likely I will have to take all 6 injectors out and send them away but I know especially with 'not so run of the mill' cars on the road other owners have much more experience so if any other 1hd-fte owners have had similar symptons and then been fixed I would like to hear it.
I am pretty sure I have the dual stage injectors, any experience of companies people have used that know these injectors and how to set them up would be good too. Otherwise will be going to our local-ish injector place known as electro-diesel.
Sorry for long post, I usually get to the bottom of most mechanical faults fairly quickly but with no codes or testing equipment at my disposal others experience is going to be very useful.
Will try and grab a video tomorrow if I remember before I park it up.
Thanks in advance,
Dan
Thanks in advance,
Dan
