Hey guys, just putting this out there to see if anyone knows what it is or can confirm what I already suspect with my 1HZ.
I have a HZJ105R 2006 model with a stock standard 1HZ. Always serviced by me, never had an issues other than black smoke which seems common in these.
Last week I did a trip from Darwin to Ayers rock and back. Set off the first day and about 200km in noticed the car seemed to be missing occassionally, figured I just got some dirty fuel and pushed through. It stayed the same most of the day but once I got to around 1200km into the trip it was happening fairly consistently though I still had power and could sit on 120km/h easy.
Fast forward to 2 days later on the trip back and it was missing consistently by the time I hit Three-ways, about 900km from home, and by 1 hour later it would only sit at 110km /h flat to the floor.
As the day went on it got worse and by the time we got home 80km/h was tops. I gave the engine a rev at home and a puff of blue smoke came out when the miss happened, pretty sure its unburnt diesel. It seems to start missing whenever I go above 2000rpm.
Has anyone had a similiar issue or know of it? I'm thinking I've lost compression in one cylinder at least and I'm getting it tested tomorrow to see if that is my problem.
Thanks in advance!
Thanks in advance!
