Geordie Paul
Got round to fitting the suspension lift today. Still have the rear left corner to do. What a fiddle As most people have said the rear shocker took a bit of tightening up (took Chis's advice and ground the old one off )
Only problem is I forgot to measure the ride height prior to lifting and i dont think i have got much lift on the front at all. The measurements i took after the lift are from the ground to the wheel arch, front is 92cm and the rear is 95cm. I will measure it again once i have taken it for a run.
It would be much appreciated if someone with a standard truck could take the same measurement and let me know what their truck measures. Mine has 265 70 16 on at the minute.
I took it to a friend of mine who is a mechanic before i lifted it to get a few tips, he was amazed at how high it was already. He works on quite a few of these and he has not seen one ride as high as mine as standard. The Springs were definitely newish so could be slighlty longer than standard. Anyway as long as i can get 285 75 16s on it doesnt really matter
Will post some pics once i finish the job tomorrow.
