Read through the add
http://www.ebay.co.uk/itm/TOYOTA-LA...2TD-LOW-MILES-12-MOT-TAX-SERVICE-HISTORY-/110
New one on me Roger, i knew you can take one prop off.
A modification in Australia is to convert from permanent 4 wheel drive to part time 4 wheel drive in an attempt to decrease fuel consumption.
Roger
And to have a turning circle, rather than a turning zig-zag! Ever noticed the difference with the 70 series between 2 and 4wd?!
This is difficult to do in practice as you can't hold 4 wheel drive on a sealed surface for long enough to check but our Shogun is locked into 4 wheel drive all the time and stability on wet surfaces, especially through deep puddles is far better than the 70, which is basically rear wheel drive.
Something else that comes to mind was a period in my life when I drove a Leyland ready mixed concrete truck. This was a 10 wheeler with two back axles that were fitted with diff locks. When these were engaged, the turning circle was 50% greater.
Roger
