75 amp battery good to use as a starter battery?
Good day
Is a 75 amp battery good to use as the starter battery? I am Ethiopia. I drive a landcruiser colorado 3 litre turbo diesel. The KZTE engine. Its a 2000 model.
I look forward hearing from you.
The only battery I can get here is a Trane. Do you know if its any good?
Join the all-new Windows Live Messenger family
http://get.live.com
Karen,
This is a bit difficult as the vehicles in the Uk are a bit
different. I would say that the battery would be OK as Toyotas do
start very well. I have never heard of Trane but if you have no choice
why bother to ask.
2009/7/7 karel stroebel <[Email address removed]>:
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
Is that 75 A/hr or 750 cc a you mean ?
Behalf Of karel stroebel
Sent: Tuesday, 7 July 2009 9:18 PM
To: [Email address removed]
Subject: [ELCO] 75 amp battery good to use as a starter battery?
Good day
2000 model.
_____
Free upgrade for your Windows Live Messenger! Click here!
<http://get.live.com>
sounds like a "normal" petrol car battery - it will start the 1kz-te engine
(i used one for a while to start my 1kz-t) however it does get f*cked
quickly. it will not last as long as a heavier duty 110ah battery. all the
safari operators in ethiopia use big diesel lumps with twin batteries (24v
starting systems) so there should be heavier duty batteries around if you
search.
-- -- | great britain | zimbabwe |
m +44 (0)776 860 6729 | h +44 (0) 1273 600 793 | s |
www.--
_____
from: [email address removed] [mailto:[email address removed]] on
behalf of darren mcrae
sent: 07 july 2009 22:30
to: [email address removed]
subject: re: [elco] 75 amp battery good to use as a starter battery?
is that 75 a/hr or 750 cc a you mean ?
behalf of karel stroebel
sent: tuesday, 7 july 2009 9:18 pm
subject: [elco] 75 amp battery good to use as a starter battery?
good day
is a 75 amp battery good to use as the starter battery? i am ethiopia. i
drive a landcruiser colorado 3 litre turbo diesel. the kzte engine. its a
2000 model.
i look forward hearing from you.
the only battery i can get here is a trane. do you know if its any good?
_____
free upgrade for your windows live messenger! click here!
hello karel,
the ah rating is not an indication of how good a battery is at
starting the engine. what matters is the cold cranking amps (cca)
rating. if the trane battery has roughly the same rating as the old
battery, it should work. otherwise, expect premature failure.
rgds,
roman (london, uk)
'92 hdj80 (auto)
on tue, jul 7, 2009 at 11:00 pm, Fred - africa 4x4
cafe<[email address removed]> wrote:
e engine
e
v
on
on
european land cruiser owners mailing list
further info: http://www.landcruisers.info/
