80 Series CV's?
Just a small update, SKF don't hold any stock of the cv VKJA 5610 anymore. ODM or genuine?
May just do one side at a time and save up in between using genuine parts.
GKN/Löbro is a good alternative. GKN is a OEM supplier for most German car manufacturers.
Well thats one side done!!!
The cv was an original one so it hasn't done too bad. New king pin bearings, and the upgraded spindle housing bearing, not sure if its better or not than the bush?
I found so wear on the shaft for the axle oil seal, buts its ok for the next few years.
Changed the engine oil and filter.
Need to sort out the window motor now!!!!!
