80 Series Power Steering Hoses
Ambrose22
Hi Veterans!
Just joined and hoping for a bit of help! Power steering pump is leaking and was gonna do an overhaul but the high pressure hose are ouch expensive from toyota! Any of you know of cheaper options. And any advice on what and not to replace! Thanks
SteveJB
Where abouts are you based then if a member is close ish to you then they should be able to make a recommendation for somewhere close by
Iwan
wales
You can get hydraulic rubber lines made up. Just use clips to fix the pipes down in places so they don't rub on other things And a lot cheaper than obtaining the expensive new stealership ones.
