slightlyriskyneil
- Jul 11, 2015
Hi all - my problem seems to be one of a common theme: I have a 90 series D4d common rail type engine which has been putting me in crawl mode and when tested the guy says the fault was low fuel pressure (no fuel pump in tank). With some effort and trickery I can get it started and she idles fine and revs up for a while but soon the light comes back on and starting is difficult once again. I have eliminated there being any air leaks right up to the fuel pump (changed filter as well). The SCV's at (27 degrees Celsius) gave a reading of 2.4 with no variance between the two so I'm assuming they're fine. I can't believe there's a problem with the injectors as she runs so well (when running) and I am lead to believe that if the pump had failed swarfe would have buggered the injectors in any case. I'm hopefully leaning towards a misreading fuel pressure sensor (no fail as this would have shown on the diagnostic) or a faulty pressure relief valve.
Any suggestions ?
p.s. I'm poor ....................
Any suggestions ?
