Roger Fairclough
- Dec 14, 2010
The small rubber bellows cover on the axle end of the h/brake had started to break up and dirt and water were getting in. I took the cable off the motor and stripped off the damaged rubber. I suspended the cable in a vice by the lever end and started to dribble in Viscotene spray grease. As I dribbled the oil in I moved the inner cable up and down to pump the oil through. By the time the oil had penetrated right through, the original stiff cable was running freely. I will probably seal the axle end with a suitable rubber bung, held in place with a lightweight spring.
Roger
Roger
