- Mar 1, 2010
There is a timer piston inside the pump. This is kept in the standard timing position by a spring. One standard timing hot or cold. However it is overridden and dictated to by the much stronger spring on the ACSD lever spindle which has the ACSD on it. This allows the ACSD to advance the timing when cold. If the assy is removed and a blanking plate fitted the pump returns to it's standard timing by the action of the timer piston spring. Completely correct for hot engine but slightly retarded for cold engine. (The ACSD also idles up the engine when cold so this item will be lost).
When the ACSD assy is fitted the thermo wax contracts as the engine cools. This causes the thermo piston to withdraw allowing the ACSD spindle to rotate. The spring on this spindle is much stronger than the timer piston spring which therefore fails to keep the timing standard and it becomes advanced to suit a cooling engine.
The spindle has a small lever on the inside acting on the timer piston. When cold the lever will be touching the piston and overriding the piston spring so the piston will be forced into a more advanced position. When the engine gets fully hot the lever will move so as not to touch the piston. When fitting a new thermo wax it's important to make sure this gap is created by sufficient action of the thermo wax. First the timing should be measured and recorded ( in accordance with the WSM overriding the ACSD ). Then the engine should be warmed up and the ACSD lever clamped in position to keep the hot position and then the engine be allowed to cool. Then the timing should be measured again (without override) and if the thermo is adjusted properly the timing should be the same. In fact the spindle retard lever just leaves the piston at 50 deg c to be absolutely correct. If the gap is not maintained it could lead to failure of the mechanism as it is not designed for constant use.
