Nuclear Chicken
- Apr 9, 2010
Crispin,
As far as I know, Toyo only use (sell) the DOT5.1 and they assured me that is works i.e. mixes and replaces, any lower DOT fluid. I also read it somewhere. I replaced most of my fluid about April last year when I discovered a few leaks in corroded lines, and 5.1 was all I used. And since that agin when I replaced front calipers last summer. Worked perfectly since. You will need 2 people though. Don't let the fluid run lower than min in the resevoir. If you get air in the servo system, according to the repair maual, it's a right royal PITA to get it all vented again. Ideally have a man on the pedal and watching the fluid level and then run round the nipples yourself. Bit of a guess at which point old starts to change to new but you'll have a reasonable idea from the amount you add to the resevoir.
